Configures an existing virtual machine (VM) CPU allocation.
vm | Designates a virtual machine. |
vm_name | Specifies the VM name to configure. |
cpus | Designates specifying the number of CPUs to allocate to the VM. |
num_cpus | Specifies the number of CPUs to allocate to the VM. Range is 1–2. The default is 1. |
By default, the number of CPUs allocated is 1.
The number of CPUs allocated to a VM is set when the VM is created (default is 1), but you can change the allocation with this command. To view the number of CPUs currently allocated to a VM, use the command show vm {vm_name | detail}.
This command does not take effect until the next time the guest VM is started.
The Integrated Application Hosting (IAH) feature requires the Solid State Storage Device SSD-120.
The following example changes the number of CPUs allocated to VM "vm1" to 2:
# configure vm vm1 cpus 2
This command was first available in ExtremeXOS 30.3.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
